Solid mount or no?
Solid mount or no?
Tryin to decide if I want should with solid motor mounts on my conversion turbo build.
If its solid mount, I can brace the turbo off of the frame, Poly motor mounts I would need to have it all supported on the motor itself so the crossover pipes don't break?
Vehicle will be 99% Street driven, which do most go with? And if most do go Poly, how did you mount the turbo?
-Cory
-Cory
-Cory
-Cory
Simply because you listed 99% street driven as a goal, I would stay as close to normal for a stock turbo setup as is possible. A lot of people underestimate the amount of vibration, noise, and maintenance they REALLY want to put up with for a street car. This (for me) would mean cast manifolds or good headers and "maybe" bracing from the heads. Solid motor mounts wouldn't even be a consideration.
Honestly I went solid after my downpipe and crossover smoked the stock mount and the difference was incredibly small, not what I expected at all. I must have had a lot of slop in my dieing factory mounts because the whole car felt more solid and really lifts up when the turbo comes up. Truthfully, my car has never been down the track, lots of street miles though and I really like them. I was quite worried before they went on that there would be a lot of vibration too.
