Does anyone know the stock timing...
For nitrous I would strongly recommend an aftermarket ignition box with on demand retard and rev limiter at the very least and a window switch would bve a very good idea too. Mallory 685 is a good choice, some guys like MSD, whatever just use something.
Have the pcm based rev limiter set a good bit higher than you will set the box. The stock rev limiter cuts fuel which is instant death for the motor if that happens while spraying.
