Wiring rader detector
Old 08-29-2008, 06:23 PM
Havoc54's Avatar
Default Wiring rader detector
What is the best way to hard wire my radar detector? So I don't have to run the cord down to the cigarette lighter.
Old 08-30-2008, 10:30 AM
Brian2006's Avatar
What kind of radar detector?
The best way is to wire it directly to the fuse box through the headliner and down the A-pillar.
Old 08-30-2008, 11:43 AM
cookba's Avatar
you can also wire it right there into the rear view mirror wiring if that is where it will be mounted. there is this thing called invisicord that comes ready to hookup and go.
Old 08-30-2008, 04:12 PM
Brian2006's Avatar
I for one, took the next step and wired my own mute button and indicator LEDs:
http://ledvault.armorysound.com/Bria...ches%20015.mpg
You could always go this route
Old 08-30-2008, 05:06 PM
cookba's Avatar
^^hahahaha we aren't all technically or electronically inclined as some people.
Old 08-30-2008, 11:40 PM
Havoc54's Avatar
That LED set up is pretty cool. But I don't think I could pull off something that complex. Its going to be under the rear view mirror so i think I'm going to see about just wiring it into the mirror. That is, as soon as I get my new alternator in.
Old 08-30-2008, 11:45 PM
Andrew1989's Avatar
All you need to do is just get a 12 volt source that shuts off when you take the keys out and a ground. It's very easy, just look around the fuse panel and the wires under the steering wheel. It takes longer to hide all the wires and to make it look good then wiring it.
