4L60 to 72 speedo
I thought 93's had 'mechanical' speedos, but I guess I don't quite follow what they mean since I know mine isn't cable driven and neither was my 91, or my 90 Suburban.
Pull the tailhousing and check the tailshaft to verify it has what you need. You should see 2 small holes after you pull the tone ring off. If you have holes, you are fine; all you need to do is buy the correct speedo gear and the small metal retainer clip (that fits in the 2 holes) and slide it on. Then, just get the speedo cable portion for a 700R4 and put that in the tailshaft housing.
If your output shaft doesn't have the 2 holes, some guys have put the nylon ring on and epoxied it but I wouldn't recommend that. IF the holes are missing, pay a trans shop to swap the output shaft out for a 700R4 one that used a mechanical speedo. If they have a used output shaft, they should only charge around 100-150 to swap it out for you.
Duh. Good point. There are also boxes that came on mid 80's suburbans that hook up to a cable output on the trans. You have a stub cable that goes to the box then your regular speedo cable hooks up to the output side of the box. The box has the built in pulse generator to feed the PCM. You just have to get the PCM flashed to calibrate it for the proper pulses per revolution so the trans shifts correctly.
