bbk 52mm question
bbk 52mm question
well installed a 52 and it whistles like i have a baby blower under the hood. eithere way i noticed that the iac wasnt ever drilled out and i have the blades open slightly as well..
used my scanner and my tps at idle is .91 a bit high
at w.o.t its 4.67v
iac was 40 and going down a bit
my idle was around 700 in drive and goin down a bit too
now i want to get rid of the whistle and get my idle to smooth out a bit more i reset it by holding throttle on for 10 secs with koeo then koer for 10 secs then off for 10 and start vehicle it seemed to get idle to be better but stilll a little surge. what are peeps doing for the whistle to go byebye and get the idle to smooth.
or will a tune get rid of all this and i can leave it the way it is and let the tuner fix it all.
at w.o.t its 4.67v
mine whistles too, and my idle sucked at first. I replaced the TPS and elongated the holes and the idle went fine. I am living with the whistle for now, but if it is not supposed to whistle like that i would like to know how to fix it too.
the only way to get rid of the whistle is to throw away the BBK. The casting is off and what you hear is air seeping around the blades...
You can get TPS and IAC right by drilling the hole.
start with 1/8" hole (same size as stock TB_). First reset TPS so closed it is about .67vdc and 4.5 vdc full open. Then drill the hole and scan IAC...they want to be about 32 (30-35). If the IAC is still to high drill 1/64" bigger NO MORE and scan again. On motors with more cam you may even need slightly larger hole...11/64" but take 1/64" steps. There is a big swing in IAC count in those incriments.
Remove TB each time to drill hole...or shavings WILL get in motor.
My stock TB started whistling after I put my tune in. I like it Sounds like it's actually be modded
I haven't slapped my 58 on yet, but I don't recall it whistling on my TPI setup.
