NX wet kit on stock lt1?
Old 08-30-2008, 08:33 PM
blake110106's Avatar
Default NX wet kit on stock lt1?
What Shot could I safely run? I plan on having full exhaust before I spray it. Also I'm having my trans built by a local Racing Shop. What would be a good size stall to run with it? is there and install write up?
Old 08-30-2008, 08:42 PM
robsquikz28's Avatar
what kit is it or part number
Old 08-30-2008, 09:07 PM
http://www.shopatron.com/product/par...20920-10/300.0
There is the link. Its a new kit I trade a PS3 for to a guy that works at NX. He said it was a wet kit.
Old 08-30-2008, 10:01 PM
indeed its a wet kit stock type lt1 u can hit it with a 100 shot with that kit no problem at all
Old 08-30-2008, 11:58 PM
awesome! are they hard to install?
Old 08-31-2008, 08:32 PM
nope not at all
Old 09-02-2008, 09:07 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
stall size will depend on many factors other than nitrous....cam, weight, gear, use of the car etc, will all play into the stall choice.
For a bolt-on car I would recommend 28-3200, if you have plans on adding a cam I might go with 32-3600 now.
As far as installation there are many wiring diagrams posted in the sticky above....everything will be pretty straight forward on your LT1.
Please let me know if you run into any issues.
