Heads Cam Guys what Nitrous kit are you using?
I'm looking to use a progressive controlled 100 shot on my heads cam LS1 setup. What Nitrous kit would everyone reccomend? Wet or Dry?
Re: Heads Cam Guys what Nitrous kit are you using?
TNT F1 for me. NO CONTROLLER NEEDED. If you have traction...spray it out of the hole.
But I plan on upgrading to a NXL Direct Port when the new motor is in.
Sell me the TNT ...lol
So a regular wet kit and no controller will be fine?
Do you guys hook on the street w/ H/C/N20 without a controller?
Restricted User
I dont hook anywhere unless I am on ET Drags...
Yep, wet kit outta the hole and a lil 150shot.
Maybe they should rename the NOSZLE kit the 'Spider' Kit, those things look so dayum busy. My friends is similar..
Well naturally I'll be on Et streets when I go to race, and was thinking a dual stage or a progressive controller work well on the street and spray the bitch all the way out of the hole on the track? does that make sense?
Restricted User
Makes sense, but....Nitrous really aint legal inside a car on public roads....with that being said I did see this one NBM 2000 Z28, nailed the throttle on the bottle and spun like a biatch for a couple blocks on heated DR'd...NO TRACTION
I think if I get caught racing having the bottle hooked up is the least of my worries =)
Thanx for all the replies guys
How does this sound
TNT F1
Bottle Heater w/ Bottle Pressure Guage
Purge
NX maximizer (it has a built in Window Switch)
Any other saftey stuff needed?
How does this sound
TNT F1
Purge
[quote]
Depends on local laws, but actual use is hard to prove. Unless of course they have an open bottle valve law. [/quote
yea...open container laws suck.......
How about a blow down tube and pressure fitting?
Good thinking
Anyone know where I can get the prices for this stuff? Not all sponsors have them
Best thing to do on the street is hope it will hold in 2nd or so if not wait to spray in third. I rarely have a problem holing in third. Unless it's a cool night. As far as out of the hole i still cant get the ETStreet's to hook on a 100shot.
