Moser Yoke ?'s
Moser Yoke ?'s
How can i tell the difference in a 1310 and a 1350? I measured the cup at 1 1/8 in with a tape measure. I hear a 1310 doesn't need a new u joint and the 1350 does. is that correct? thanks
The spread in the u joint is wider on the 1350. Both the 1310 and the 1350 will require a new u joint to work with the stock driveshaft, as the oem is neither of these. Bob
