P0420 & P0430 Help!!!!!
Old 09-01-2008, 12:48 PM
LS1NUT26's Avatar
Default P0420 & P0430 Help!!!!!
Well it started off being just P0141 (o2 sensor) and then before I could fix the O2 sensor, The codes P0420 and P0430 came up also. I replaced the O2 sensor and cleared all of the codes and a few key cycles later these two codes came right back.
The codes mean Catalyst System Low Efficiency Bank 1&2
What does it mean?
Will they go away by themself?
How can I keep them from coming up/ fix the Problem?
Thanks for all input.
Old 09-01-2008, 12:52 PM
slow's Avatar
P0420/P0430 are catalytic converter low efficiency codes.
Since you sig says "MAC ORY Pipe (catless)" I am assuming they are the cause of the issue.
Ryan
Old 09-01-2008, 01:01 PM
LS1NUT26's Avatar
I never head these codes pop up until after I had the O2 sensor code.
the cats have been off for some time now.
Old 09-01-2008, 01:43 PM
2001NBMZ28's Avatar
P0141 is the post-cat drivers side 02 heater circuit, which one did you replace? Are you running sims?
Old 09-02-2008, 09:48 PM
LS1NUT26's Avatar
that is the same sensor that I replaced.
not running sims.
the codes 0420 & 0430 didnt come up the same time that the o2 sensor code.
it came a few weeks later.
now only getting these to codes.
Old 09-03-2008, 07:33 AM
Jedi Master
Gh0st's Avatar
You don't have cats, so why would you even have the codes enabled? Turn them off. It's pretty standard to turn them off when you have a high flow cat anyways.
Old 09-03-2008, 08:17 AM
Engine_HP's Avatar
plus one......
Old 09-05-2008, 09:46 PM
LS1NUT26's Avatar
Can I get the codes turned off anywhere for FREE?
and Where?
Old 09-09-2008, 03:56 PM
LS1NUT26's Avatar
going to try to put cats back on to see if it fixes it
Quick Reply: P0420 & P0430 Help!!!!!
