tach and engine temp connection issue
Hello all,
Im new here. Im installing a 00 LS1 in 98 Volvo wagon. I have every wire accounted for, but I cannot figure out how I will make the stock volvo tach, and engine coolant temp gauge work. according to the factory diagram thels1 system (00 camaro ss) has one wire(C2 pin # 50 DK GRN/WHT) that comes from the pcm and feeds a processor in the instrument cluster information for engine temp, tach, and speed, the processor then sends the appropriate signal to each gauge, so do i need to get a camaro cluster and wire in that processor into my circuits? or ?? I also see a wire (C2 pin 10 WHT) which is the engine speed output and GM has that running to the EBCM (brake module) can I use this wire for the tach ?? In terms of the coolant gauge im lost. Thank you in advance, also if you can please email me direct as im not familiar with this forum stuff. tightfd@yahoo.com.
Ivan
Ivan
The White Wire(Engine Speed) is your Tach Signal.
The one wire that you are talking about that feeds everything the Signals is known as the Serial Data Wire..the Oil Pressure, Speedo, Tach wires can be found seperate. You will have to splice onto the Red wire that comes from the Alternator to get the signal for that.
Here is how you do the Temp wire..
Get a 1998 F-body LS1 Temp Sensor(GM Part #12551708) and get a 3-Pin Connector identical to the one that is on the Throttle Position Sensor.
Wire in the bottom wires the same as the Connector that is currently in there..keep the 2 bottom wires on the sides that they are on, and then the third wire is the wire that goes to your Temp Gauge. I currently have mine setup like that, and I have no problems.
The reason you have to do this and the reason this works is cause the F-bodies that are 1998 and back use Analog Gauges, the 1999 and up use a BCM(Body Control Module) that sends one signal to the Gauges and it breaks it down digitally from there.
The three pin temp sensor is used only on the 98 F body and mounts in the same place the PCM sensor does on the 99+ engines. Problem is it won't do a thing for you on the Volvo as I doubt it will drive the volve temp gauge. My advise woud bo to try to find a place to install a Volvo temp sensor. Also. The LS PCM tach output would be the same as a 4cyl tach signal. So if your Volve had a 4cyl you may be in luck.
Re'
Re'
I used a Volvo temp sensor in the cylinder head (side with the unused sensor location). Dakota Digital makes a tach signal converter that will interface with the Volvo tach. Can be programed for any combination. About 80 bucks. I see that by 98 the Volvo tach runs off the ECU and not the primary side of the coil like the earlier ones did. It IS very possible that your tach will work just fine off the GM wiring.
Buy some tuning software like EFIlive that can change the tach signal if needed. You will need it anyway if you intend to keep your ride OBD2 compliant.
coolant temp gauge
Ivan
You should be able to cut into the yellow/white from A14 on your cluster and with the key on try around 150 ohm resistor to see where your guage will be. Once you find where your temp guage will be in the center, then look for a suitable coolant sensor that shows "that many" ohms at running temp.
If I get a vehicle in the shop the next few days I'll post it for you. That Y/W wire will partially ground the guage.
