Which knock senors? Where to get them?
There were 2 different knock sensors used in '98 F-Bodies. One style had like a water bottle nipple connector, and the other was a clip style. There's no way to know which sensors you have until you pull your old ones out.
You have 2 options: Pull your sensors first and then go order the correct ones. Order both sets of sensors and make sure your dealer will take the unused set back (which is doubtful if it's a special ordered part that they don't stock).
I had the dreaded 3.9 degrees of KR at WOT and new sensors seems to have solved my problem. I've got the water bottle nipple sensors BTW.
