Looking for info on who has replaced axles
Just found out today that my axles have to be replaced, so just wanted some help with some info on who has had to replace their axle or both Also what type of car with the year and mileage. Along with was it one or both axles. Just wondering after all the searching I did, what year and type vehicle has been having the most problem with axle's. Thanks alot
Example
2002 transam firehawk 38000 miles Both axles
Example
2001 Z28, used to run 9's before I got it. 88,000 miles.
Not even sure it's the original rear.
Drivers side, just replaced the drivers side front hub at 90,370. Maybe the previous owner was fat.
These cars are bad for eating axle bearings. If you are careful you can catch a bad bearing before it screws up the axle. Very common problem. By the way I replaced both axles @ about 70K.
first time I read this is a problem.... what exactly is wrong with ur axle? how much u gonna spend to have it fix? and most important, how do you drive it?
2002 SS 6-Speed. 55,000 miles..... Axle bearing on DS went bad and chewed up the axle.. Replaced the bearing and axle. Got a Moser axle from Jaws Gear.. Great Service!
When I bought my car the rear rotors were warped, so I don't know if that caused the bearing to go bad or not
Thanks guys, keep it coming!
