i replaced the opti..now hard to start
Old 09-03-2008, 09:57 PM
atv.mike's Avatar
Angry i replaced the opti..now hard to start
hello all i just replaced the opti on my 94 z28 i also removed all the smog junk and the a/c.since then the car has to crank over a bunch be 4 it fires.....any ideas???
Old 09-03-2008, 10:49 PM
Fixxer99TA's Avatar
What kind of opti did you use?
Old 09-03-2008, 10:52 PM
Green3spd's Avatar
does it run ok once it starts...?
Old 09-04-2008, 04:10 PM
atv.mike's Avatar
summit,and it runs awsome wen it finally starts you just gotta crank it a bunch
Old 09-04-2008, 04:27 PM
Fixxer99TA's Avatar
I wouldent go with anything but AC Delco for a stock car, or MSD/Dynaspark or something like that for heavily modded (or just higher revving) cars.
I am not totally sure on who makes the Optis for Summit though...
Old 09-04-2008, 06:28 PM
jarretthise's Avatar
ive heard that is a typical thing for an aftermarket opti...at least your car runs lol....and yea the best way to go is ac delco...alot of the aftermarket ones are junk...
Old 09-05-2008, 08:25 PM
96fifolt1's Avatar
I drove to Jegs in Columbus Ohio and got one of there (jegs) brand name opti and the wire harness would not fit in the hole correctly. I took the power feed harness with me when I took there opti back and we tried three different opti's and the plug would not go all the way down in the hole. It was offset or something. We pulled a GM Performance Parts one out and the power plug fit like a glove. On something like that I would not trust anything other than factory GM I was not happy that I had to take the opti back off and make another two hour drive and change it out.. lesson learned on my part steer away from house brands and stay with proven parts
Old 09-05-2008, 08:29 PM
Fixxer99TA's Avatar
Any updates atv.mike? Interested to hear how it turned out...
Old 09-07-2008, 07:16 PM
atv.mike's Avatar
na nuthn new still runns its *** off just dosent start easy..hey will taking the smog junk off do anything to the timming??i herd it does.....
Old 09-07-2008, 07:18 PM
Fixxer99TA's Avatar
No, you just need to cover up the holes for air/egr and get the codes tuned out.
Old 09-07-2008, 08:14 PM
clwz28's Avatar
Default opti
Its a bad opti,summit optis are china pops,just like the junk on ebay,I tried three,all bad ,first one acted just like yours.
Old 09-07-2008, 08:42 PM
Fixxer99TA's Avatar
True, all knock off optis seem to give trouble...
Old 09-07-2008, 08:50 PM
viperdad's Avatar
What is the optis? and does it make it hard to start? I have a 94 Firebird whit a 5.7 that you have to crank the **** out of it...if you pump the gas pedle like a old carb. motor it will start and run great. Got 42 lbs of fuel pressure....and thoughts
Old 09-07-2008, 08:53 PM
Fixxer99TA's Avatar
Optispark, its on the front of the motor (on the timing cover) under the waterpump. Its the LT1 system of distribution, and has the cap/rotor and 2 sensors inside it (opti high/low res signals for timing).
Yes, an optispark going bad can cause you to have to "crank the ****" out of the car at first.... But it still may run seemingly fine after. Eventually it will go totally and cut the car off completely.
Old 09-09-2008, 06:34 PM
viperdad's Avatar
Would that give you a code if it is bad? and is that like the cap with all the spark plugs go in to and is like $300.00
Old 09-09-2008, 06:56 PM
chavez885's Avatar
Doesn't give a code, Yes.
Old 09-09-2008, 08:08 PM
viperdad's Avatar
What is the code and where is the best place to get one
Quick Reply: i replaced the opti..now hard to start
