Installed Pro Kit today...HELP
So I installed my Eibach pro kit springs today...the front springs went on KYB AGX adjustable shocks...and the front rides nice....for now, the rear springs are still on the stock shocks...and I did the Hose mod ontop of that....well, my SLP LM1 Is LAYING on my axle. The rear end is like a friggen pogo stick. My exhaust is as high up as it can possibly go, and theirs still a good amount of room between the rear tires and the fender...so, How Do I fix this? BFH mod?
LS1TECH Sponsor
A few things.
1. You should not run the isolator removed mod on lowering springs
2. The exhaust has to pretty much hit the upper PHB brace before anything else and that relationship does not change with different springs.
3. Your ride is not being helped by the fact you have stock rear shocks (pathetic they are).
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
im gonna put the rubber isolator back on today...
Their is no adjustable hanger on my exhaust...but Im gonna pull the hanger off, and see if I can push the exhaust forward more about 1/2"...this will give me the axle clearance.
