McLeod Clutches
Old 09-04-2008, 03:39 PM
lt1z28camaro's Avatar
Default McLeod Clutches
What do you guys know about them? Are they worth the extra money? Do I only need the clutch and flywheel? I was recommended to get a single disc clutch with steel flywheel. Comes to be $815. How much power do these clutches hold? Sorry i've searched and havn't found anything, didn't get any help from manual transmission section either. Any help is much appreciated!
Old 09-04-2008, 04:40 PM
FlamingChicken's Avatar
i have a street twin and love it. the twin holds 900lb/ft i think. not sure on their single discs. you dont really need to replace the flywheel unless it is worn or damaged. just friction disc, pressure plate, and throwout bearing. might want to replace your pilot bearing too.
