Toggle switch for fans??
Old 09-04-2008, 04:38 PM
LM97Z's Avatar
Default Toggle switch for fans??
Is there a wireing diagram to do this, where do i tap into? I sold my Hypertech while still running the 160* stat, need to be able to turn the fans on manually now.
Old 09-04-2008, 04:41 PM
Counted Out's Avatar
You should be fine with just the 160* thermostat, but if you want to add the fans, I think shbox.com has the diagram.
Old 09-04-2008, 07:32 PM
93lt1M6z's Avatar
i had SLPs manual fans. was around 60 bucks and taps into your computer...took me 20 minutes to install and worked great...just me though
Old 09-04-2008, 07:44 PM
black_sunshine's Avatar
here, this should be what you are looking for.
http://shbox.com/1/fan_sw_diagram1.jpg
http://shbox.com/1/fan_sw_diagram2.jpg
Old 09-04-2008, 08:57 PM
Smokinlt1's Avatar
I uesd shoebox method as well using a 3 dollar 3way switch.
Old 09-04-2008, 11:24 PM
LM97Z's Avatar
Thanks..
Old 09-05-2008, 08:31 AM
the_merv's Avatar
I took apart the Fuse Box under the Hood there and pretty much re-wired everything. I re-built the Circuits to where each Fan is controlled by one Relay, and I have a 2 Switches in the Car controlling the Fans.
Old 09-05-2008, 08:59 AM
LM97Z's Avatar
I really just want a simple toggle so i can turn them on when i want.
Old 09-06-2008, 07:57 PM
Smokinlt1's Avatar
Cant get much simpler than the 3 way switch
Quick Reply: Toggle switch for fans??
