To seal rear end: use gasket? RTV/gasket maker? Or both??
I have only th gasket now and its leaking.
So i am thinking about getting a new gasket and using the blue gasket maker stuff. Someone told me to use just the gastetmaker and ditch the stock gasket. Does that sound right? This is for a 3.42 10bolt.
Re: To seal rear end: use gasket? RTV/gasket maker? Or both??
I use black RTV, just a thin layer and install the rear cover (actually we did one last night on an LT1 car), it saves the cost of the gasket and if applied properly (to a clean surface), they never leak).
Just my thoughts....
I usually use both. Extra security, but when I changed the oil in the rear end right after I got my car, there wasn't any RTV or a gasket. It was bare metal to bare metal. No leaking though for some reason.
