Moser 9" and lca relos
I am about to purchase a moser 9". I already have lca relocation brackets on my 10 bolts. Will the lca relos swap over to the 9? Or do I have to have them welded on by moser when I do the purchase. Also, at exoticperformance, I noticed it said that 3 channel is not available with the aluminum center section. But I think I saw a picture of someones with a sensor and reluctor ring installed. So can I do the 3 channel with the alum. center section?
You can reuse your lca brackets, but you'll have to do some grinding on them to make them fit. We've done it many times, it's not that hard to do.
Moser currently has suspended the 3 channel with the alum center section, due to a parts related problem. Thanks! Bob
I have a Moser 9" and I didn't have the lca brackets welded then, I should have cause now I need to grind some powder coating off to have them welded.
"Moser currently has suspended the 3 channel with the alum center section, due to a parts related problem. Thanks! Bob" is this 3 channel w/ alum center section only? mines not 3 channel I bought mine less then a year ago, do I need to worry about this??
