ignition switch issue
Any ever have a problem with their c/5 switch. I started my car the other day, and all the guages stayed still as if I did not start the car. now if I slightly move the key to the left the guages begin to work. This happened like 3 times in a row. any suggestions? 2004 z06
I never have heard of this problem before. Try doing a search on the Corvette Forum for ignition failures. You will probably get a lot of column lock bypass threads, but there may be a post for your specific problem too. Good luck getting it fixed. Better do it before it leaves you stranded.
