You can also keep it on the Fast intakes. Just have to cut out the hole with a hole saw. Tells how in the instructions and comes with the screw for it also.
The typhoon comes with the egr blocked off for the '02 and later, but you can remove the plate for the earlier cars and install the fitting that should be on the end of your hose already.
