DynoTune Fully Automatic Adjustable Nitrous Bottle Warmer Kit – $89!!!!
LS1TECH Sponsor
We are offering our complete Fully Automatic Adjustable Nitrous Bottle Warmer kit for only $89!
This Bottle warmer is the best available on the market and uses the smallest most accurate pressure switch available along with a heater element offering unsurpassed performance. The Dynotune pressure switch is fully adjustable and holds the pressure within 50 PSI. It comes with all the components to install right down to the fuse holder and fuse! Your choice of orange or black!
http://www.dynotunenitrous.com/store...p?idproduct=17
To place your order: Go to our secure website and place your order - pricing has already been updated!
Dean
Dean
Has a small adjustment screw on it. Basically turn it all the way up. Then, once the bottle gets to your desired operating Psi, you SLOWMLY dial back down the adjustment screw. Does this somewhere where it is quiet, and you can audibly listen for the hobbs switch to kick off.
-->PS off the top of my head i think the switch is rated to only adjust between something like 650-1300psi.
LS1TECH Sponsor
Thanks for the good words!
How long it takes would depend on what your starting pressure is. I guarantee if you purchase the heater kit you will not be dissapointed!
Here are some additional comments from 2005! We pulled this out of the archives to show you this heater has been strong and steady for many years!
https://ls1tech.com/forums/showthrea...ghlight=heater
Dean
Dean
Race your car!
I have a dynotune heater, thing works great I've been using it all season and ahve had no problems, about a 1/2 hour and I can have a 600 psi bottle up to 1100 with no problems, I can easily get the bottle from 800 up to about 1100 in 10 min or less depending on the outside temp in the staging lanes too.
