Timing Chain Question
Old 09-05-2008, 04:57 PM
Elliott's94Z's Avatar
Default Timing Chain Question
I'm doing a Lloyd Elliott LE1 this fall and was wondering if I will be ok running the stock single roller gm timing chain?
Old 09-05-2008, 05:05 PM
JustinsZ's Avatar
Dont know why it wouldnt be okay, I know plenty of other people including myself that have had no issues.
Old 09-05-2008, 05:08 PM
I've been told the stock single roller is weak and upgrading top to the heavy duty or dbl roller would be a better choice being I will be right there during the head/cam swap.
Old 09-05-2008, 05:09 PM
Fixxer99TA's Avatar
I would just put a stock replacement in there, the LE1 isnt too extreme. I have seen many run more powerful setups with just a new chain/gears.
If your really worried or intend to go a little more crazy, get the upgraded LT4 chain or go to the double roller.
Old 09-05-2008, 05:16 PM
Not worried so much just want to do it right the first time rather then tearing back in if a prob occured. I already have a new chain and sproket so I guess I'm set.
Old 09-05-2008, 06:36 PM
StealthFormula's Avatar
I always recommend to people to get a new stock gm chain for sure and sprockets if the mileage is really up there but for the most the chain is enough. I've been running the stock chain with the 503 and now again with the LE2 setup and its been great. Buddy of mine has been running a new stock chain with his 383 LE1 setup with good luck as well.
Old 09-05-2008, 06:45 PM
96capricemgr's Avatar
Well for starters the stock one is neither weak or a roller. More guys break "extreme duty" sets than stock ones. Have to consider that the stock linkbelt chain was designed with the fairly substantial load of the waterpump in mind and it does a good job of handling that load.
Old 09-05-2008, 07:35 PM
BOLO's Avatar
+1. When I did my H/C in 2005, I replaced them with new GM original--timing chain, sprockets(cam, crank, waterpump). They're strong enough.IMO.
Old 09-05-2008, 07:39 PM
I can always count on you to correct me when I state wrong info "roller"..lol I appreciate it though!! I'm gonna use my new stock set up. Thanks guys.
Old 09-05-2008, 07:53 PM
The reason I corrected it is because people hear "single roller" and "double roller" and assume the double roller is a lot stronger, which it may be but since the stocker is not a single roller that does not apply.
Actually look at a stock chain, look at how many straps there are at any given point. Now look at the "performane upgrades", roller is about friction reduction, not strength.
Old 09-05-2008, 08:06 PM
I hear "single roller" all the time. In fact, I think Summit used those words if I remember..
Old 09-06-2008, 09:22 PM
James Montigny's Avatar
Stock replacement will work fine.
Be sure to get one specific for the 94, the 95+ won't fit unless you have a vented opti and 95+ timing cover.
Remember to degree the cam when you install it.
Quick Reply: Timing Chain Question
