Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
fuel tank conversion
Old 09-05-2008, 11:25 PM
firstgenguy's Avatar
Default fuel tank conversion
Has anyone used there stock first gen camaro tank for a fuel injection setup? I would like some ideas instead of buying a 600 dollar rock valley tank. Wondering if there is another intank pump unit that will work in the stock take. Thanks for any help.
Old 09-06-2008, 03:47 PM
TODDS93T/A's Avatar
hows the inside of the tank you could sump it or use a areomotive in line f/p
Old 09-08-2008, 08:30 AM
69 Ghost's Avatar
I did a first gen tank by modifying it probably more than you would want to. I cutout the large opening from another tank and took the filler neck then had it welded onto the first get tank. I also had 2 tanks and split them and dropped one so that I have a 22 gallon tank. This is what I run in my car now. It was a bit of work but well worth it. If you use the original cap setup with a pressurized tank it will spill gas out the back when you gas it.
Quick Reply: fuel tank conversion
