Brake Upgrades
Old 09-06-2008, 12:04 AM
ImpSS08's Avatar
Default Brake Upgrades
Hey guys. New to the site. Just got an 08 Impala SS few months ago. I'd like to upgrade the brakes. I'm not satisfied with the stopping power of this heavy car. Anybody have some suggestions? I'm not looking for a big brake kit or even a full brake kit. Just some better but very streetable pads and rotors. What would you guys recommend? Thanks. Joe.
Old 09-06-2008, 01:31 AM
Corny40's Avatar
There are a few choices out there...
R1 Concepts, Baer (makes front rotors for our cars), Tons of **** on eBay. I went with EBC rotors and pads and I'm very happy thus far.
Old 09-06-2008, 02:19 AM
4doorSS's Avatar
I would def like to get some new brakes these things feel like they get hot too fast im glad to know its not just me who doesnt like them
Old 09-06-2008, 10:03 AM
98Jeep360Limited's Avatar
I bought the AC Delco drilled and slotted rotors with ceramic pads for mine, I'm very happy with them.
Old 09-06-2008, 05:24 PM
mike690003's Avatar
whered you get the ac delco drilled and slotted rotors from?
How much did they run you?
Old 09-06-2008, 05:53 PM
I got the rotors through my work ( AC Delco dealer) They were about $75 each I believe, and for some reason they dont make rear drilled and slotted rotors for 06+, so I had to use 00-05 Impala rotors, which are identical to the 06's anyway, dont know why they even bothered changing part #'s.
Old 09-06-2008, 08:52 PM
fastLS4's Avatar
Another vote for EBC Pads and Rotors.
Old 09-07-2008, 04:07 PM
MonteSS8707's Avatar
Had EBC red stuff pads on my 01 MCSS and got em on my 87MCSS. Good ****!
Old 09-08-2008, 12:25 PM
Ls4GXP's Avatar
I know you said that you don't want to change the whole brakeing system but you might want to know about the 05-08 gxp factory brake systems 12.7 front & 12.0 rear drilled rotors best I've ever had even better than the 04 gto I had.......look around you might get lucky and find good salvaged parts for the right price.
Old 09-08-2008, 03:16 PM
ImpSS08's Avatar
Thanks for the information everyone. Seems like there are quite a few easy upgrades that several people are happy with. And to LS4GXP would this be a complete bolt up? Or will there be rim clearance issues? I've read about the front wheels being wider or something on the GXP is it because of the calipers? Thanks again guys.
Old 09-09-2008, 08:32 PM
Ls4GXP's Avatar
GXPs come with 18s stock, 17s would clear the bigger brakes but 16s would not thus means that your 16'' spare tire wouldn't work. As for why the front rims are designed wider (255mm)vs(225mm) is all for performance and handling and does not effect the brakeing system your stock 18s will clear it, this should be a complete bolt up but I'm not exacly sure, but I know one thing it will clear everything because the GXP and the ImpSS are identical body design called W-Body.............IMO 99.95% sure it will work without a sweat............best bet go test drive a GXP and see for yourself if you like the brakeing system.
Old 09-09-2008, 09:05 PM
HardBlu's Avatar
A guy at work has a GXP and the rotors look nice. I may just change mine for the look. I like the black calipers against the silver.
Old 09-10-2008, 07:17 AM
fastLS4's Avatar
Problem is that the Impala has 12 in the front and 11 in the back.
You would need the whole braking system from an 05-08 GXP to pull this off.
Old 09-10-2008, 09:00 AM
20SS07's Avatar
Plus the GXP's don't stop any shorter than the Imps do so I don't know how much of an "upgrade" it would be vs. just aestetics. Now I'm sure with repeated hard braking the GXP system will hold up better, however just looking at basic stopping distance you're not gaining anything you're better off just going aftermarket.
Old 09-12-2008, 03:52 AM
onehotss's Avatar
Any links to drilled / slotted rotors for 08 impala ss to websites baer and so on.. please post...
Old 09-12-2008, 11:26 PM
Do a year/make/model search on ebay or summitracing.com for best results and prices.
Old 09-13-2008, 12:08 PM
onehotss's Avatar
Are the rotors all the same on the IMPALA models, LT LS LSX SS?
Old 10-04-2008, 10:56 AM
giddyup's Avatar
I do believe that the brakes on all impalas from 2006 on are the same. SS, LT, LS, LTZ all the same brakes
Old 10-06-2008, 08:48 PM
HardBlu's Avatar
i was checking into this and the cross drilled slotted GXP rotors are the same for the 06 to present SS's since each have 18's. Im looking to purchase when I need a set for looks.
Old 10-06-2008, 11:17 PM
4doorSS's Avatar
these stock brakes suck anyone know if corvette brakes will fit?
Quick Reply: Brake Upgrades
