What PCV valve do you use?
Old 09-06-2008, 02:06 PM
TS6
TS6's Avatar
Default What PCV valve do you use?
I still have the PCV hooked up stock style (to the valve cover, no LS6 valley cover) going to the intake manifold with a catch can. I thought I might replace the PCV valve as maintenance. I know some guys just use a check valve and no PCV, but didn't know if that would be too much vacuum? Looking for advice on what to use.
Thanks!
Old 09-06-2008, 03:27 PM
Jrp1978's Avatar
Default hmmmmm
Sam have you looked inside the intake with your setup know to see if you got oil! I understand what you where telling me lastnight about how you have it hooked up , but i just cant believe you are not oiling the hell outta the intake! Lotta go post on here about the whole system!
Old 09-06-2008, 10:51 PM
TS6
TS6's Avatar
No oil in the intake at all. I do have a oil/air separator though.
