What is this and how do I stop It from leaking?
I went to put on my fuel rail covers and this started leaking after i put it on, it's the metal piece on the fuel line ....
i bet if you look down in there one of the rubber o rings is missing i have saw them fall out when you remove the fitting if you havent moved the car look around with a flash light see if you see laying around i am almost positive that is what happend
Its the metal piece inside.....theres no o ring.....I even checked my brothers which is actually not leaking and there is no O ring....prolly just need to order fuel line from dealer
I just went to NAPA and they had GM quick disconnects in 3/8 and 5/16.
The feed for our cars i think is a 3/8. These do have the plastic oring inside of them. I will see if I can snap a few pics tonight.
Here is a pic of mine. Notice inside that behind the orange thing its just metal, an empty place.
Here is what came out of mine.
Notice the new one has a yellow/clear plastic oring inside.
The old one next to the one i found at NAPA
What do you guys recommend I do? Cut off the old end and put it on that hose, or replace the entire hose, with new ends on both side. What type of hose do I buy?
That Hose Actually Comes Apart A Little Further Down That End On The Engine Is Only The Extension...i Think I Have A Spare One Laying In My Shop..or You Can Get One At The Dealer...i Wouldnt Run A Spliced High Pressure Line Unless I Wanted To Burn My Car To The Ground.
So the stock quick disconnect actually comes out if you pull hard enough!
The replacement I bought is identical, except that it doesnt have the curve in it.
Here is the new one next to the stock one before I installed it.
[QUOTE=Monello;10117042]So the stock quick disconnect actually comes out if you pull hard enough!
I HAVE NEVER SEEN SUCH A PIECE....HAVEN'T TRIED TO INTENTIONALLY PULL THE END OFF OF MINE EITHER THOUGH...SO HOW DID IT GO GET DROWNED WITH HIGH PRESSURE GASOLINE SPRAY OR DID IT ACTUALLY ALL SEAL UP AND WORK LIKE IT WAS SUPPOSE AND NOT CATCH EVERYTHING AROUND IT ON FIRE???
