Generation IV Internal Engine - 236/242 .580/.590 on a 112 lsa cam +ls6 Heads?
hayabusa
09-06-2008, 06:09 PM
236/242 .580/.590 on a 112 lsa can this be used with stock ls6 heads and springs?
Summerwolf
09-06-2008, 06:17 PM
I would put better springs in there but people have put bigger duration/lift on ls6 heads before and made good power.
LS1Z28-00
09-06-2008, 06:23 PM
def need springs anything over 550 lift and the springs are not going to be enough and a valve is going to kiss a piston.
hayabusa
09-06-2008, 07:12 PM
Comp 918 springs good enough?
Summerwolf
09-06-2008, 08:27 PM
918s would be one choice. PRC duals would be a little bit extra insurance.
Stroker396@APF
09-08-2008, 11:41 PM
I am using 918's with a 233/236 w/ .592/.598 with no issues. But I only have a few thousand on it so far, but it has been run hard at the track a few times to the rev limiter on Stock LS1 heads.
4yall2nv
09-09-2008, 02:21 AM
great cam choice, go with a higher lift like 615/615 and use the prc duals. i run this cam and have gone 11.5s, cam only
