making it hook
Old 09-06-2008, 08:43 PM
2fast4u2catch's Avatar
Default making it hook
i have a 97 camaro i am swapping in an all out race sbc and a glide. right now i have a moser 12 bolt and bmr adjustable lower control arms. everything else is stock. i want this car too hook HARD what are some of the better piece to make an f body hook? any suggestions will help because of right now i have nothing.
thanks Justin
Old 09-07-2008, 12:59 PM
AChotrod's Avatar
Adjustable TA, Drag springs and Adj shocks. Oh and some slicks
Old 09-07-2008, 04:16 PM
any particular brand?
Old 09-07-2008, 04:27 PM
teke184's Avatar
hard to go wrong with BMR, i've had good luck with them.
if its a straight drag car..relocation brackets work wonders...even at stock spring height.
but the torque arm will help...i would suggest putting a TA relocation bracket on it as well. get the pressure off the trans tailshaft (if the glide even has that).
might want to look into SFC to keep the frame straight...although you may have a cage to take care of that.
disconnect the sway bars...or run a drag rear sway bar...which BMR sells too.
Old 09-08-2008, 04:02 PM
BMR Tech's Avatar
thanks Justin
What kind of rear wheel horsepower are we working with?
I am sure we can put together a proven combo for you
Quick Reply: making it hook
