Where can I find a 3 keyway single roller timing chain?
Old 09-04-2003, 08:38 PM
nuzee's Avatar
Default Where can I find a 3 keyway single roller timing chain?
I couldn't find any.
Old 09-04-2003, 10:15 PM
SStrokerAce's Avatar
Default Re: Where can I find a 3 keyway single roller timing chain?
The Comp 3153KT is a infitely adjustable from 6 deg Advance or Retard. They are made of billet, and have a roller thrust bearing.
We sell them for $173.75
Bret
Old 09-05-2003, 01:57 AM
nuzee's Avatar
Thanks for the info. I thought all of those hex-adjust type sets were double chain. I'm looking for a simple type 3 keyway single roller or if necessary a single non-roller chain set. If there is a hex-adjust, single-chain cam gear that will work with the stock chain, I'd be interested in that too.
Old 09-05-2003, 07:01 AM
Zatlanta's Avatar
"I went w/a Jwis chain part# : HME-G68VC-60, and Cloyes Hex-adjust gears (single) # CLY-9-3153A. The chain is a true single roller, every bit stout enough to handle 600 + HP. This is the same chain Katech used in the C5 they built to run and win the 24 hours of LeMans. The Cloyes gear set does come w/a chain....but, is basically just a stock chain. The Jwis chain is beefier, and IMO has a better fit. Eliminates all that slop you've got in the stock chain." (orig quote LowETz)
Quick Reply: Where can I find a 3 keyway single roller timing chain?
