Need Help Asap!!!
Your Speedo or the complete dash.
If just the speedo, you need to plug into the obd2 port with a scanner and see if it is showing vehicle speed thru the computer. if it is, then there is a short or bad ipc.
If it is not showing anything in the scan tool, then it is a burnt wire, disconnected wire, or bad speed sensor.
