kenne bell 2.8l on a stock bottom end LS1
Old 09-07-2008, 12:41 PM
86MonteSS's Avatar
Default kenne bell 2.8l on a stock bottom end LS1
if i run it at the minimum PSI (10 PSI), will it last a few months until i get a built engine put together to throw in? or is that way too much for the stock bottom end?
Old 09-07-2008, 01:30 PM
Subliminal Hit's Avatar
just keep the tune really safe and you'll be fine. Plenty of cars here between 500-600 wheel on stock bottom end that lasted a while.
Old 09-07-2008, 02:38 PM
98Z28MASS's Avatar
Its a crap shoot when in comes to over 500 rwhp. As stated above if you have a real good tune with plenty of fuel and say a meth/alky injection kit as a safeguard then it should last for a decent amount of time. Again though its all in the tune as ive seen cars pushing less power/boost on a stock engine and had it fly apart really quickly due to a crappy tune. Good luck though and post up pics of your build when you have them!
Old 09-07-2008, 02:43 PM
86MonteSS's Avatar
hmmm....maybe i'll just buy the kit and wait until i can drop a built engine in to install it. :-)
Old 09-07-2008, 02:49 PM
95 Z28's Avatar
Only one way to find out...
I'd do it.
Old 09-07-2008, 03:22 PM
Z06PSI's Avatar
Mine didn't last too long at the power level in my sig.
Old 09-07-2008, 03:33 PM
Self-Admitted Scammer
ls2pontiac's Avatar
Just run it, make sure you shut it down when you hear a rod knocking to save the block
Old 09-07-2008, 03:39 PM
Z06PSI's Avatar
Or when crankcase steam is coming out from under the hood at idle sitting a stop light after a WOT run. 5 pistons were broke.
Old 09-07-2008, 05:25 PM
N4cer's Avatar
Pfft! That's nothing! You still had 3 to go!
Old 09-07-2008, 08:03 PM
stevensLS1's Avatar
you could but personally if i had a KB sitting in my room there's no way i could just let it sit there lol. good luck with whatever you decide and keep us updated!
Old 12-14-2008, 08:16 AM
86MonteSS's Avatar
Decided on heads/cam. Once I get a little more cash, a zex direct port n2o kit. Possibly with a standalone
Quick Reply: kenne bell 2.8l on a stock bottom end LS1
