FAST rails w/ A4
FAST rails w/ A4
Ive got a 05 GTO, and recently installed a set of FAST fuel rails to go on my FAST 92 and SVO 42# injectors. Thing is, the fitting for the inlet is on the rear passanger side fuel rail, and I cant bolt on the A4 dipstick with the fitting there. its all on there right now, but i dont like leaving the dipstick unbolted. does anyone have a solution?
Trade sides on the rear Simple. or pull off fuel rail put dip stick bold back and and bend it out of the way then put fuel rail back on! Never mess with a GTO but i have worked on a ton of f-bodys and those are my solutions
i had thought about putting it on the drivers side, but i was told not too cause of the bends. i dunno if its even possible though. the line would go from the hard line adapter to the 120degree bend, to about an inch or 2 of hose, then a 90deg to the rail.
i guess ill pull the dipstick tube out and bend the tab. i didnt think of that
you dont have to take the dipstick tube out! Pull that side of the fuel rail off and then bolt the tube back up and then bent it out of the way with in bolted up! When thats done put fuel rail back on!
