General Maintenance & Repairs - I Need This Bolt!!
silver30th
09-07-2008, 11:26 PM
OK, so I wasn't sure where to put this, so if it needs moved, move it...
Anyways, I am looking for the following pictured bolt. It appears to the k member (maybe?) to the body of the car. It is shorter than the rest of the k member bolts, and if I remember correctly, 18mm (socket size)
If anyone has this, PLEASE PLEASE PLEASE let me know, as I am missing the one from the drivers side!
Thanks!
http://i8.photobucket.com/albums/a24/cdm18911/IMG_0230.jpg
silver30th
09-08-2008, 11:53 AM
lunch crowd bump!
anyone have a parts car or anything they could pull one off?
2002_Z28_Six_Speed
09-08-2008, 12:25 PM
I would try the dealer. You will be able to get it in 1-2 days and at least you know it won't fail.
99monguse
09-08-2008, 12:43 PM
I need a bit more information. Is this the bolt that holds the lower control arm on? Is it in the front or rear?
99monguse
09-08-2008, 12:48 PM
There are four bolts that hold the crossmember to the frame the dimensions are:
M12x1.75x92 49 THD and the GM part number is 10234622.
silver30th
09-08-2008, 04:09 PM
front of the car is pictured
i went to the local GM dealer, but he said the biggest bolt (socket size) on the front of the car was a 12mm, this is 18mm
99monguse
09-09-2008, 07:53 AM
I show four bolts holding the K-member to the frame. Can you get another picture but a bit further away so I can tell where this bolt is in relation to the k-member? The size of the bolt I listed (M12x1.75x92 49 THD and the GM part number is 10234622); the M12 is the diameter of the bolts shaft not the head where your socket goes. The head of the bolt may very well be 18mm.
Black FormulaLs1
09-09-2008, 11:19 AM
maby you could check a bone yard? or check the for sale section as part of a part out car thing?
silver30th
09-09-2008, 05:05 PM
here is another view, obviously with more in the picture...i drew a box around it (go photobucket!)
http://i8.photobucket.com/albums/a24/cdm18911/IMG_0234.jpg
silver30th
09-09-2008, 05:06 PM
ah shoot, it didnt save the edited picture
it is the bolt in the center of the picture, to the left of the abs wiring
silver30th
09-12-2008, 01:49 PM
there's the box...bump
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
