Has Anyone Converted to a Short Front Spindle?
Old 09-08-2008, 09:39 AM
JasonWW's Avatar
Default Has Anyone Converted to a Short Front Spindle?
I'd like to know if there are any short spindles that will work on our cars in order to fit the upper balljoint inside the rim. Similar to the C5 and C6 design. Obviously you will replace the upper arm with a longer one and move it's pivot point lower.
I know guys have converted over to a strut suspension for drag racing use so maybe someone knows about this as well?
Here's what I'm talking about:
The reason for this is to get rid of the shock towers. Thanks.
Old 09-08-2008, 05:36 PM
tpunk's Avatar
There was something about drop spindles over on frrax a while back. You might want to look over there.
Old 09-08-2008, 06:00 PM
fast377's Avatar
I've seen it for the fox body guys. It converts the strut setup to a dual a-arm setup similar to what you are talking about. I've never seen it on an fbody though.
Old 09-08-2008, 08:30 PM
Suaveat69's Avatar
In the LSX for sale section there is a car with pictures of eliminating the towers similar to what you are talking about.
Old 09-08-2008, 08:53 PM
Suaveat69's Avatar
https://ls1tech.com/forums/vehicles-sale-lsx-powered-only/972705-camaro-roller-4-link-strut-front-etc.html
Old 09-08-2008, 09:27 PM
JasonWW's Avatar
That's something completely different.
Towers are still there, just in tubular form. Neat, but not what I'm talking about.
That might be similar, let me look into it.
This is what I mean by eliminating the towers:
It's similar to a truck or a vehicle with an actual frame instead of a unibody. It may be possible to use the C5 spindle if I make a custom upper A-arm. I'm going to look into that as well.
Old 09-08-2008, 09:54 PM
fast377's Avatar
Here is the Griggs setup for the fox mustangs.
Is that kind of the conversion you are talking about?
Old 09-08-2008, 11:03 PM
JasonWW's Avatar
Yeah, that's basically what I'm talking about. Once you reinforce the lower frame, you can cut off the shock towers.
I think you need to find a spindle with the proper Ackerman built in or else one where you can fab your own steering mount.
Old 09-09-2008, 04:50 PM
fast377's Avatar
That's true...but there are a lot of spindles floating around that could probably be made to work (maybe even a vette spindle). I'm sure it's all do-able. It's just finding someone to ruin the front subframe to try and mock it all up...now that I mention it, I might know of one (I've been trying to get a wrecked car from a guy for a while now).
I would think that you would be able to drill the k-member mount holes all the way through and build off the top of that, adding all the necessary brackets and bracing. But I haven't really looked at it. If it's anything like the front frame rails on my thirdgen, then the metal is pretty shitty to start with. On that note, I would be VERY intersted in this setup for my thirdgen (I know it's a different suspension setup, but I'm just throwing it out there as this type of kit is more in line with the intended purpose of my third gen).
Someone needs to do this.
Old 09-10-2008, 12:02 AM
JasonWW's Avatar
I think the best thing to do is to put the upper a-arm mounts on the top of the k-member. That way the entire front suspension is held together as a complete unit.
The front frame rails are basically made out of stamped sheet metal, maybe 16 gauge, but the factory did spot weld some reinforcement pieces to the inside walls.
Here is a quote from member John_D.
When there is nothing tieing the two frame rails together, they move pretty easily. My engine is out, and I cut off the upper and lower radiator supports for a radiator relocation project. I can grab the end of the frame rail and move it easily. But not up and down, and not side to side. It moves diagonally.
There is a brace that runs under the fender, from the firewall to the headlight. That brace keeps the rail from moving toward the headlight or away from it. But it doesn't do anything to prevent movement at a 90 degree angle from it. (see quickie ms-paint jpg below).
I would definitely not lift the car by the frame rails for an engine removal, with those supports gone. The k-member will be the only thing keeping the front of the rails from floating.
I modified his picture a bit.
Here is a frame rail cross section near the firewall.
I've already done a lot of research on the front structural design and have numerous dissection pics of these cars.
Old 09-10-2008, 12:08 AM
JasonWW's Avatar
Sliced in front of the springs.
The way things look, the a-arm mounts would need to be right where the frame rails are.
You could:
1. Replace that section of the frame rail with 2x4 rectangular tubing, offset to the inside, and mount the arms to it.
Or
2. Add mounts on top of the k-member and keep them separate from the frame.
Old 09-10-2008, 12:50 AM
JasonWW's Avatar
This spindle has potential.
Its from the 67-69 F-body and there are several variations out on the market. There is a stock short version and an aftermarket tall version. I'm looking at the tall version. Notice it has a seperate steering arm and is available in a 2" drop version. Did I mention they're fairly cheap as well?
The one thing against it is that when compared to the 4th gen spindle, the drop is only about 1". Maybe that is OK?
Old 09-10-2008, 01:15 AM
JasonWW's Avatar
Notice the upper A-arm mounts in this pic. Something like that can be welded to the top of the k-member.
These are older pics of mine and upon further review I believe the shock towers would move rearward AND toward the center of the car as this pic shows.
Old 09-10-2008, 01:34 AM
JasonWW's Avatar
What I think may be necessary is to build a front sub frame and weld it into the unibody structure like in the pics below. The one difference being that both the A-arm mounts will be attached to the k-member instead of the frame.
Old 09-10-2008, 01:48 AM
JasonWW's Avatar
Just for reference, here are the 4th gen "frame rails".
My black car in the shop. Green shows the front "frame rails" and blue shows the main body "frame rails".
Since most folks don't know about the main body rails, here's a better view.
I love this pic from RagenZ28:
Old 09-10-2008, 05:18 AM
InsaneAuto86's Avatar
Good idea. Looks very simple and a lot of weight reduction could be accomplished.
Old 09-10-2008, 05:38 AM
JasonWW's Avatar
I think the weight will go up, not down. I'm thinking these cars were built a little too light to begin with which is why they flex. I don't know, might come out about even.
It won't be easy either. I figure you have to pull the engine/trans, support the car so the door gaps are good, than brace the k-member to the firewall and floor. Then cut away the towers and front frame rails. Then build your new frame rails to fit on top of the k-member and tuck into the floor area. Weld up both sides and then add any extra bracing it may need from top of firewall to front rails. Then you should be able to bolt K-member on and get to work on the upper arm mounting.
It's a lot of work. I don't know if I'm ready for that much.
Here's a real nice story on converting a unibody car to a full frame. They put the entire body in a jig to told it in place. There are some real amazing build ups posted online from this shop.
http://www.hotrodscustomstuff.com/ph...-firebird.html
Old 09-10-2008, 06:41 AM
JasonWW's Avatar
I just had a radical idea! Instead of a regular 4x4 tube frame, why not use 2 rails of 2x2? Lower one might be best for square tube and probably round tube for upper one. Here's the general idea. Look at the stiffness you'll get. You'll have plenty of room for the upper A-arm mounts.
Old 09-10-2008, 03:27 PM
tpunk's Avatar
Maybe I'm missing something, why exactly are you wanting to do this? I'm not sure I see what is to be gained by such a venture... other than being really cool.
Old 09-10-2008, 04:13 PM
JasonWW's Avatar
I don't know about you, but there are numerous benefits to me.
Quick Reply: Has Anyone Converted to a Short Front Spindle?
