Big shots inside! 250+ Whats your setup?
Old 09-08-2008, 10:44 AM
NVR4GET's Avatar
Default Big shots inside! 250+ Whats your setup?
What is your set up?
Mine
Motor: 427 sleeved ls2 10.5CR
Tranny: Built M6
Kit: NX Fogger four noids (high pressure)
Shot: 300 on a FJO progressive
Fuel: stand alone by nitrous outlet (high pressure)
Plugs: NGK TR8's
Timing: 18 degrees
Buttom/Switch: WOT under peddle
Old 09-08-2008, 10:47 AM
Race your car!
JL ws-6's Avatar
Any reason you went with a high pressure fuel setup rather then a low pressure?
Old 09-08-2008, 10:55 AM
NVR4GET's Avatar
I had a low pressure fuel system on my brothers camaro, I didnt like how every time you adjust the fuel pressure just alittle it would make a huge change. Were as with the high pressure its easy for me to dial in the A/F easyer.
Matt
Phantom_LS2's Avatar
GOOD GOD! 300 shot! LOL
Old 09-08-2008, 11:14 AM
NVR4GET's Avatar
I built it for a big shot and now I think I will stay here. I had a 200 shot on my stock bottem end forever and never hurt anything.
Matt
Old 09-08-2008, 11:18 AM
stevegrizzle's Avatar
What clutch......my stock clutch hates me on a 125 shot.
Old 09-08-2008, 11:21 AM
NVR4GET's Avatar
I have a McCloud twin disk, its slipping really bad. Its at McCloud getting rebuilt with there Meeba Linning and hopefully will hold.
Matt
Old 09-08-2008, 11:50 AM
Cool, I'm looking to get info on some clutches and rear ends so I can make my car more than a roll racer
So far it looks like a textralia oz700 and midwest fab 9" rear........now I just need teh moneyz!
Old 09-08-2008, 12:24 PM
hashtagBMW
Speed Density's Avatar
Is your dp 2 stage capable Matt?
Old 09-08-2008, 01:08 PM
Race your car!
JL ws-6's Avatar
Matt
I do understand that aspect of it, but my concern was with the jets being so small on the fuel side I worry about something getting in one of them and clogging it up and then having a really bad day.
With that type of shot I'd still be flowing the fuel system to verify the pressure with it.
Old 09-08-2008, 01:30 PM
NVR4GET's Avatar
I do flow the kit, but when I am tunning the A/F on the regulator it is so much easy with high pressure. I am in no way saying the high pressure is better, I just like it because its easyer.
Matt
Old 09-08-2008, 01:59 PM
ATVracr's Avatar
Take more timing out and run a colder plug.
What jets are in the fogger? what Fuel pressure?
Old 09-08-2008, 02:25 PM
daniel6718's Avatar
ive got high also...i also think its easier to fine tune...
Old 09-08-2008, 02:32 PM
ATVracr's Avatar
There is alot more info and people to help with the low pressure stuff.
Dry fogger for the win.
Old 09-08-2008, 03:08 PM
Cliff's Avatar
I have a high pressure system 200 to 500.
http://i271.photobucket.com/albums/j...IMG00351-1.jpg
Old 09-08-2008, 03:12 PM
NVR4GET's Avatar
I can remeber the jets of the top of my head, but fuel pressure is 44-47 psi depending on the A/F and weather of the day. We use to run 21 degrees on my brother car on brother 408 and a 300 shot forever with out a problem, we set it at 18 once to try the 400shot but she just spun. whats your set up? those time are nasty!
Matt
Old 09-08-2008, 03:30 PM
TRMIN8R's Avatar
Motor: STP 347ci, Stock Block and Crank, Scat Rods and Diamond Pistons
Tranny: TH400
Kit: NOS NOSzle Kit
Shot: 275, all at once
Fuel: stand alone by Solid-Technology.com (low pressure)
Plugs: NGK TR8's
Timing: 16 degrees
Button/Switch: Nitro Dave's Window/WOT Switch
Old 09-08-2008, 03:48 PM
Race your car!
JL ws-6's Avatar
Jesus I need to add some timing, I'm still on 17 degrees with a 150 hit LOL.
Old 09-08-2008, 04:17 PM
ATVracr's Avatar
I've been saying it for a while now.... there isnt much power in timing, the right A/F has alot more power than a couple degrees of timing. The problem is when you start to get the A/F close to right is when the timing will melt your ****!
Good luck to those of you running rich tune ups with alot of timing.
Run the car with 2-3 degrees out and I bet it doesnt slow down. Then leave the timing out and take some fuel away and watch it go faster.
IMO TR8's are not cold enough for a 300 shot.
I'm at a 350 shot and running NGK 11's .... hell I'd run 12's if they made them. lol
ATVracr's Avatar
I'm in the single digits on a 350 hit.
Quick Reply: Big shots inside! 250+ Whats your setup?
