Dual intank pumps & 60lbs injectors
Running dual 255walbro pumps and 60lbs injectors with stock lines and rails what kind of power could be supported at the wheels?
I have looked but didn't find a clean cut answer.
LS1TECH Sponsor
Depends on the car.....
My dual pump kits are good for atleast 1000rwhp.
Stock lines are stable up to about 750rwhp
60# injectors are good for approx 900rwhp if boost referenced..... if not boost referenced, they can max out at 750rwhp or less depending on your boost & power level.
If you want injectors, a pump setup, a complete kit, or something in between, feel free to give me a call.
Im running Lonnies dual intank setup and 60lb injectors. Ive put 6k on the pumps and no issues at all. I have it boost referanced to see about 80psi at 15psi of boost. At 530whp on a mustang dyno,9inch,unlocked my injectors were at about 70% duty cycle.
Alex
Alex
