well ive had the car for only 50 days and already have a problem :(
so i go to get my oil changed on my gxp used full synthetic castrol car has 24k miles i hope i made the right call..... but anyway the idiot goes to put air in one of the tires but as hes putting the cap back on the part inside the rim that holds air in the tire shot off and i was sitting on a flat. the metal was corroded or something...( at 24k miles ? ) so i had to drive to a dealership get the whole thing replaced and since we have the fancy tire pressure monitoring system it cost 166 bucks,(tires arent covered under warrenty ) for the whole thing. guy said they discontinued the part because it happens alot so they switched to rubber ones now. so just want to give you guys a heads up becareful when you go to put air in your tires
