anyone have any links to cheap HID kits and we req h4 right?
I just basically need a link to a site that has good reliable hids and will the stock housings be able to take hid h1's?
Thanks
matt
Thanks
matt
I have HIDs. All I needed were the EuroLights conversion housings and an HID kit. Unless you don't feel like spending $70 on the housings and just pry the bulb out of your stock ones, then seal them in with gray sealant.
Your gonna need to cut off your factory harness for your headlights, it's just a ground and power wire. Then your gonna have to crimp on wire connectors on the end of each wire after you've stripped it back a little, then plug it into the HID harness.
Here's mine:
The fence pic was before I aimed them correctly, thats why it's up way too high and uneven, lol.
Fogs are 8K HIDs and Lows are 12K HIDs. PM me if you want the link, they're from ebay so I cant post it here
Here's mine:
