valve springs
Old 09-09-2008, 11:26 PM
snk-huntr's Avatar
Default valve springs
can you guys lead me to a set of wallet freindly springs to work with a hot cam and 1.7 rrs? thanks.
Old 09-09-2008, 11:27 PM
LSWHO's Avatar
Hot cam kit includes all spring hardware if you were to buy that.
Most will tell you 1.7s are a mistake also... ...so you know its coming.
I'm going with the Crane 10308 kit when I cam mine.
Old 09-09-2008, 11:39 PM
snk-huntr's Avatar
i already have the hot cam and 1.6s installed im just upgrading to 1.7s why would that be a mistake?
Old 09-09-2008, 11:40 PM
StealthFormula's Avatar
Crane 10308-1 Kit. Do not use the springs in the kit because the 1.7's will put the lift rating of the cam beyond what the springs are capable of handling which will create issues.
Old 09-10-2008, 07:09 AM
leadfoot4's Avatar
"Stealth", have you been able to do any more work on your "noisy lifter" issues?
Old 09-10-2008, 11:36 AM
Nope I haven't, just moved up to school a couple weeks ago. I took the car to a local engine builder and he said if I put 1/2" turn preload on them it would be quiet. Bret Bauer and others told me that wont solve the issue so Im going to buy some aluminum valve covers to keep the noise in and if there still loud I'll play with the valves again over christmas and hope it works!
Old 09-10-2008, 12:30 PM
3pnt4maro's Avatar
yeah you def dont wann ago 1.7's as the springs can barely hold the 1.6s lift as it is nown in that kit
Old 09-10-2008, 05:58 PM
tspence45's Avatar
How much lift will the Crane springs handle?
Old 09-10-2008, 06:09 PM
.600"
Old 09-10-2008, 09:20 PM
3pnt4maro's Avatar
yep .600 worth
Old 09-10-2008, 11:00 PM
snk-huntr's Avatar
So .600 will hold the 1.7's and the hotcam with no issues?
Old 09-11-2008, 01:37 AM
tspence45's Avatar
Yeah, they'd be able to handle a decently big cam with 1.7's even. The lift on the hotcam with 1.7's will be at .558".
Quick Reply: valve springs
