New Springs
Old 09-10-2008, 07:44 PM
wsick's Avatar
Default New Springs
i just got a set of Eibach pro kit and wanted to get them on before i hit up the track on sunday, does anyone know if i need an actual compression tool? or can i just use a jack? let me know what you think
thanx david
Old 09-10-2008, 07:54 PM
subarubill96's Avatar
lt1 or ls1 pro kit? the rears will go in with no compressor but the fronts are more than likely going to need one, mine did at least. what shocks you using?
Old 09-10-2008, 08:03 PM
wsick's Avatar
ls1 pro kit, as far as i know i have the stock shocks but for some reason my car seems lower in from then some other t/a's w/o springs
heres a few pics
Old 09-10-2008, 08:12 PM
michaelg589's Avatar
yea your front does look kinda low. looks like the driveway is slanted so throws it off a little. youll need some type of compression tool to take the "stock" spring off of the strut.
Old 09-10-2008, 08:29 PM
hard to say due to the slant in the pic, youll def need a spring compressor if your re-using the shocks. what kinda event you going to? road race, drag strip? honestly if your dragging it id keep the stock stuff in until you change out your shocks as the stockers and LS1 prokit are gonna make it low and rough.
Old 09-10-2008, 08:40 PM
wsick's Avatar
heres another pic. the plan is to hit up the strip for the day, what do you mean when you say the stockers are going to make it rough? whats wrong with them?
Old 09-10-2008, 08:52 PM
lowering springs and your stock shocks arent a great combo IMO, your changing the spring rate without changing the part that controls the springs so your ride is going to be affected in the same manner. the stock shocks are barely good enough for the stock springs and were never designed to be used with lowering springs. just giving you a heads up
Old 09-10-2008, 09:04 PM
SOMbitch's Avatar
^^^^Yep^^^^
And not be ugly but eibach is the last I would have gone with.... enjoy riding on your rear bumpstops
Old 09-10-2008, 09:08 PM
wsick's Avatar
Originally Posted by SOMbitch
^^^^Yep^^^^
this will be an interesting turnout
Old 09-11-2008, 05:40 AM
just wanted to let you know before you went ahead and changed them and was like WTF, this rides horrible, sags, and before it kills your shocks. the LS1 pro kit is known for sagging and the spring rates were out of whack if i remember correctly. the lt1 pro kit seems to not have the sagging problem and much nicer spring rates.
Old 09-11-2008, 09:18 AM
colby72olds's Avatar
I agree with everyone, your probably going to hate the ride. Also, don't use a jack to compress your springs.
Old 09-11-2008, 07:17 PM
LS1 Freak's Avatar
Well let me tell you this, I had the LS1 pro-kit all the way around, then I swapped the rears with LT1 rears, still running on the bumpstops so I got sick of that **** and bought just the rear BMR springs, still riding the bumpstops, WTF, I have no idea, I gave up, my rear LT1 springs are for sale btw, good luck
Old 09-11-2008, 10:21 PM
wsick's Avatar
so what should i do?
Old 09-12-2008, 05:24 AM
LS1 Freak's Avatar
Well, if I were you, install them, if your rear starts to sag, replace the rears with the LT1 rears or bmr's, or if you want get you a set of bmr's and be done with it,too bad Strano dont have his in stock otherwise I would have bought his! good luck man
Here's a pic. of my car with LS1 fronts and LT1 rears so you can get an idea (stock shocks)
Old 09-12-2008, 05:25 AM
LS1 Freak's Avatar
Nice T/A BTW!!!
Old 09-12-2008, 05:36 AM
get some adjustable shocks like koni's or kyb's
Old 09-12-2008, 07:37 AM
tbird31's Avatar
you guys are hating on the ProKits. it's the most popular lowering spring out there. granted in recent times the strano springs have taken off but before those the ProKit was what like everyone run. yes there have been cases of the rears sagging but not everyones. and LS1Freak sounds like you have a different problem if you've used all those springs and are still riding on the bump stops. do you have the rear isolators in? my car freaking slammed with BMR springs and the hose mod and i'm still not riding on the bump stops.
goodluck either way my friend. clean looking TA you've got there.
Old 09-12-2008, 08:02 AM
SOMbitch's Avatar
BEAUTIFUL cars wsick & LS1Freak
I didn't mean to come across as rude or ugly so I apologize if I did Sometimes I just need to shutup Hope it works out for ya!
Old 09-12-2008, 10:18 AM
LS1 Freak's Avatar
''tbird31'' I do have the rear insulator on, I have no idea why my car wont raise up anymore, the springs are installed right, maybe the shocks are shot.Dont get me wrong, I love my front pro-kits, just the rears pro-kits sagged like **** the second week after install, thats all
Old 09-12-2008, 10:26 AM
JD_AMG's Avatar
Just install them.
If you don't like them take them out and sell them, and use that money toward better shocks.
Either way the lowering springs are not going to help your track times any.
