pacesetter install
pacesetter install
has anyone had problums with the headers and y=pipe hitting the bodey and making large tumping noise? and also what would cause the motor to rock hard at idle?
Yes, there was jus a thread a day or so ago with a guy saying how he fixed his! If it has a rough idle it could be a vacum leak, check to make sure no wires r touching the header melting or arching out, and also make sure you put them back in the right order!
Im having this same problem :S It seems like the flat spot on the y pipe is hitting the cross member, or the header itself is hitting the floor boards :S I really hope it isnt the motor mounts.
ive done several installations on customer vehicles and i found the best way is to beat the floorpan upwards of course i do it to where you cant tell it was beat to hell. then install the longtubes it will either rub a little bit or none at all. but yeah its normal to bang/
oh yea i have 02 sims for sale if you need them pm if interested
mine hits occasionally as well but one thing you can do is have a welder weld in a spring from your valvetrain if you have an old one lying around (not your current valvetrain)...provides the cushioning and still allows it to flex under load...I didnt do this to mine as it isnt bad at all
I've heard this works great, for some reason i never had this problem though, got lucky i guess.
