MTI STEALTH 220/220 CAM
Old 09-06-2003, 09:24 AM
4thGENRETARD's Avatar
Default MTI STEALTH 220/220 CAM
Anyone using this, could you post #'s and any relative feedback.
Old 09-06-2003, 09:35 AM
Bearcat Steve's Avatar
Default Re: MTI STEALTH 220/220 CAM
I am interested as well. I'm particularly interested in how tough this cam is on springs and if you live in an "EPA ****" county like I do, how easy were you able to pass emmissions?
Old 09-06-2003, 11:41 AM
Colonel's Avatar
The specs for this cam were originally designed by me and Jayson (owner of MTI) for my '02 Z28. The idea was to make better on the concept of the "Old Man Cam." I feel like we did just that.
Bearcat, here is what Jayson had to say yesterday about the spring issue with this cam...
"When installing just a camshaft, we have not found a better single spring than the Manley. They have a higher spring pressure than the Comp 918s and have had a great record for reliability. My personal opinion on spring changes is that they should be performed every 2 years with mild driving and every 18 months or so with aggressive driving. I'll typically see a small drop in spring pressures after a year of driving but it typically is not great enough to warrant changing them out."
BTW, we've been working on a variation of this cam. It's already made and we'll be testing it soon (no guarantees that it'll outperform the original Stealth cam. It may or may not.) Stay tuned.
Old 09-06-2003, 12:00 PM
Blk00WS6's Avatar
Col,
Are you going to be going with More Duration on the Variation of that cam?
Old 09-06-2003, 02:14 PM
Shoot Col, If you helped designing that cam, I have no more questions, Im guetting one period!!
Well maybe one last one: Should I change lifters? I got 35K's on mine.
I think I'll do it with a set of Patriot Heads and LT's
Old 09-06-2003, 03:06 PM
Colonel's Avatar
I hope you don't think I'm being silly, but I don't want anyone testing the SS2 cam before I do so I'll be keeping the specs to myself for now (not that they're anything revolutionary or anything. More like slightly evolutionary.) It isn't a drastic change from the SS1, I'll say that. I don't want to take any of the fun out of it for myself.
There's no reason to change your lifters, 4th Gen.
Old 09-06-2003, 05:43 PM
Colonel, thank you very much for the research and the recommendations. There is a reason that ls1tech is my favorite performance site.
Old 09-06-2003, 06:00 PM
Blk00WS6's Avatar
Col you Selfish bastard.
Nah.. Don't blame you for keeping them a secret.. Can't wait to see the results
Old 09-07-2003, 01:29 AM
lsx24's Avatar
I realize you don't want to divulge the specs, but what are your goals with this new profile, if you don't mind me asking?
Assuming it's also a "stealth" cam, I'm assuming the goals would at least be the same to a point:
- good [if not stock sounding] idle
- maximum power increase at all RPMs
- good for emissions
So, you must have concluded there is something wrong, or not optimized, on the original Stealth cam, thus the experimentation for a new profile.
If I were to guess, I would say you are trying to get the same power increase without the high lift, and maybe add a bit of overlap, with either an increased duration, split duration, tighter lsa, or a combination of the above, all while retaining a good idle. Sounds like the magic cam that a lot of people have been waiting for, including me!
Old 10-14-2003, 11:24 PM
99 Black Bird T/A's Avatar
Received 1,431 Likes on 991 Posts
What's the latest on the SS2?
Old 10-15-2003, 02:16 PM
Colonel's Avatar
https://ls1tech.com/threads/showflat...art=1&vc=1
