What Parts Are Needed For H/C Swap
Old 09-12-2008, 01:51 PM
x99ChevyCamarox's Avatar
Default What Parts Are Needed For H/C Swap
LE2 Heads
LE Custom Cam
LE Ported Manifold
Holley 58MM TB
30lb. SVO Injectors
Comp Cams 1305-16 NSA Rockers
Trickflow Hardened Chromemoly Pushrods 7.100"
Comp Cams 7702-1 Pushrod length checking tool
Trickflow Hardened Guideplates 30400623-8
ARP 7/16" Studs 134-7103
Autolite 104 Plugs
Victor Reinz 5898 .026 thickness head gaskets
This is what i have so far but what other things am i missing and if you suggest a different part then what is on there just let me know.
Old 09-12-2008, 02:05 PM
Elliott's94Z's Avatar
I would put a new timing chain and gear set on along with a new opti unit at the same time
Old 09-12-2008, 02:40 PM
James Montigny's Avatar
http://www.cardomain.com/ride/2297151/4
Old 09-12-2008, 03:16 PM
hashtagBMW
Speed Density's Avatar
Good info here:
https://ls1tech.com/forums/lt1-lt4-modifications/836200-stock-head-cam-cam-swap-guide.html
Old 09-12-2008, 05:51 PM
StealthFormula's Avatar
Looks good. Add a new gm timing chain to that list, maybe a waterpump or opti depending on the condition of both and dont forget all the other gaskets you will need plus a rtv, assembly lube and thread sealer, etc.
Old 09-12-2008, 10:15 PM
12 Second Impala's Avatar
A healthy bank account when the bottom end goes out.
Mike
Quick Reply: What Parts Are Needed For H/C Swap
