Where to unbolt the stearing rod?
Old 09-13-2008, 07:33 PM
sanders8800's Avatar
Default Where to unbolt the stearing rod?
where do i unbolt it inorder to put LT headers in?
Old 09-13-2008, 07:49 PM
James Montigny's Avatar
There's a collar down at the base of the bottom section, it has a small 10mm(?) bolt on it that you loosen.
You may have to turn the steering wheel to get to the bolt.
I've got mine apart out in the garage right now, I'll go take a pic if you need it.
Quick Reply: Where to unbolt the stearing rod?
