Sway Bar suggestions
Old 09-13-2008, 09:21 PM
PsychMuscle's Avatar
Default Sway Bar suggestions
Hey I want some suggestions...I have a 1997 Firebird with drum brakes on the rear, and 3.08 gears. And...soon I will install a rear end from a 2002 Firebird Trans Am with M6... That rear end came with the 1LE rear sway bar.
I dont know the size of my stock sway bars, and neither the 1LE rear sway bar of a 2002 FBody. But I want to know if it would be fine to use the 1LE rear sway bar, with my stock front sway bar. and I ask this, because I'm having some concerns about the stability of my car.
can someone help me?
Old 09-13-2008, 09:35 PM
redbadss's Avatar
the way i see it is, if you're gonna put a better rear sway bar on you should also put a better front sway bar as well. the stock 1le rear sway bar is 21mm the front being 32mm. the stock rear on ls1 is 19mm i'm not sure about a 97 model. if you're concerned with the stability of the car i would go with the spohn sway bar set, with that set up you will get a 32mm front, and 22mm rear sway bar, both solid and a lot stronger than your stock setup,
just my .02
Old 09-13-2008, 09:56 PM
vjo90rs8's Avatar
only 93s got a 21mm 1LE sway bar, all other years used a 32/19 combo. I'm using a 35mm solid ST front bar and a 21mm solid bar from a thirdgen, great combination and very well balanced. Heavy but cheap.
Old 09-14-2008, 10:05 AM
JD_AMG's Avatar
just my .02
I definitely wouldn't recommend combining a stock-like 32mm front bar (even though stock is hollow, and spohn is solid) with a 22mm rear.
My combination of 35mm front and 22mm rear(both hollow) is very very balanced, and going down to a 32mm front would only make the car tail happy and more loose.
Read the suspension stickies...
Old 09-14-2008, 03:30 PM
redbadss's Avatar
35mm/22mm is a great set up as well, if you go with both solid sway bars like the 32/22 it will still be very well balanced, he OP was asking for sway bars that were more stable than what he has, i was just simply recommending the spohn set up because they have great products and would be better than what he has now...
Old 09-14-2008, 05:45 PM
ZexGX's Avatar
I have a 99 V6 Bird and I upgraded the stock V6 bars to a 32mm 1LE front bar and a 19mm Z28 rear bar, with poly bushings and endlinks. It's pretty balanced and helped quite a bit, although now I wish I went with the Strano bars.
V8 powered f-bodies came with larger swaybars than what the V6 cars came with, so anything you do is an upgrade (assuming you have a V6, not a Firebird Formula V8). If you're only concered about stability at the dragstrip (in a straight line), go with a large rear bar. If you're concerned about cornering and overall handling, do a balanced setup with a hollow 35mm Strano swaybar, and change out the bushings and endlinks to poly when you can (front and rear).
Old 09-14-2008, 07:35 PM
Elliott's94Z's Avatar
I really like my Spohn set
Old 09-14-2008, 08:58 PM
z28bryan's Avatar
Can you explain more about the stability problem? Just asking since stability probably means something different between different people.
Quick Reply: Sway Bar suggestions
