PCM Controlled Shift Light
Old 09-13-2008, 10:11 PM
blazin's Avatar
Default PCM Controlled Shift Light
Here is the link to the how to and a video I made of mine today. I just used all the parts listed in the post.
http://www.hptuners.com/forum/showth...689#post143689
Old 09-14-2008, 02:24 PM
2002_Z28_Six_Speed's Avatar
Just one minor correction to avoid confusion!
By 98 all GM vehicles had PCMs and not VCMs.
I guess that is trivial but just saying...
Old 09-16-2008, 08:39 AM
Z'mnypit's Avatar
Sweet! Thanks for the link, that will give me something to do this weekend. On the realy, did you just use pin #47 for the ground on the realy? And are other year models the same as in the pin # on the pcm? Also im not sure if your vid is working or not, Everytime Ive tried to watch it I end up at the photobucket home page.
Old 09-16-2008, 09:43 PM
blazin's Avatar
Didnt use the relay. I cant even tell they are lit at night.
Old 09-17-2008, 11:22 AM
Aaron91RS's Avatar
Is there already a wire coming out of #47?
If so what's it supposed to control stock and do I cut it or splice in to it?
Old 09-17-2008, 09:35 PM
blazin's Avatar
No wire or pin. You will need to put a pin and wire in.
Old 09-18-2008, 09:40 AM
Z'mnypit's Avatar
Got any pics of where you monted the LEDs etc? the vid doesnt work or Id watch it.
Old 09-18-2008, 04:45 PM
SeaHawk's Avatar
How is the lag when shifting WOT at 6200 rpm? I'd like to see a log with this circuit connected to a HP Tuners MPVI harness (or equivalent) against the RPM PID and see how accurate it is...
Old 11-07-2008, 08:56 AM
Z'mnypit's Avatar
I did this yesterday finally and the Red connector Pin 47 did have a wire in it. It was yellow I believe. I got everything made and wired up but the LEDs have a real dim glow to them when they arent on. Guess Ill have to try a relay and see if they helps.
Old 11-07-2008, 09:45 AM
Frost's Avatar
I wouldn't try and drive a relay with that output. Try upping the resistor you are using with the LED to limit it's 'idle' current; that will get your desired result though you may have to play with it a bit.
Old 11-07-2008, 09:48 AM
Z'mnypit's Avatar
Good thinking.. Ill pick up some resistors at radio shack today.
Thanks!
Old 11-07-2008, 05:42 PM
blazin's Avatar
Mine have the very very dim glow that I dont even notice at night so I said F it.
Old 11-17-2008, 06:44 PM
Z'mnypit's Avatar
Same here but whats weird is after I put all the settings in the file and loaded it into the PCM the glow was gone. I have no glow until it reaches the desired RPM.
One last question, Is this possible on a 98? I went to do this mod to a buds 98 trans am and first thing I noticed was the hpt file didnt have the option to activate the shift light, 2nd thing I noticed was the PCM was wired differently. Is it possible to load a new .hpt from a 99 or etc and if so which pin on the PCM will be used?
Thanks!
Quick Reply: PCM Controlled Shift Light
