how much of a shot can stroker take with eagle crank and rods
Like the title says how much punishment can eagle rods and crank handle? i ask this cause i got a 408 stroker with eagle rods and crank with upgraded arp bolts and -2cc diamond pistons. I was thinking of spraying a 250 shot but is this too much or should it take the punishment
OWN3D BY MY PROF!
What compression are you going to be running? With a -2cc dish you're going to need a large chamber to bring the compression down. That larger chamber is going to promote detonation over a smaller chamber. The rotating assembly should take it fine. The thing you're going to have to watch out for is detonation and / or lifting the heads.
yeah the crank and rods are diffently not the weak point here. and diamond pistons are a great piece. but if they are not a nitrous pistion. a 300 would be the max. but a 250 is where i would stop at.
