procharger with twins --air filter
Old 09-14-2008, 04:30 PM
ZDOG's Avatar
Default procharger with twins --air filter
well got alittle fustrated to my cold side plumbing so i came in to cool off.
then i started searching. i got a 0920 kn to fit with the twin intercoolers but its a shoe horn fit. after getting that to fit i believe i found a better candidate. http://store.summitracing.com/partde...rt=KNN-RC-4760
you lose very little size wise but gain much needed clearance. the 0920 is 9" long, 6" wide base and 4.625 wide top. so you see your not losing to much but still tower the stock ati air filter.
ill tune and dyno with what i got on and then probally swap in the spring. as long as my boost doesnt change ill presume it doesnt hurt to kick the air filter down a notch
Quick Reply: procharger with twins --air filter
