MSD digital switch issue
OK so I got everything wired in and for some reason the window switch is not activating the kit. I know it's working because I used the normally closed wire to run a LED for a shift light. Maybe you cant use both the normally closed and normally open functions at the same time, IDK.....
I think i figured it out, one of the butt connectors for my solenoid grounds came loose. I went to bypass the switch and hook the relay ground directly to ground and it wouldn't activate. Found the loose wire, fixed it and it activated, so i hooked it back to the switch and I will see tomorrow if the switch will activate the kit....
