surface rust/corosion on gears
Old 09-14-2008, 05:58 PM
LS1Aggie09's Avatar
Default surface rust/corosion on gears
I am going to be cleaning up a set of gears and am wondering what is the best way to do so? Steel Wool or Sand Paper? The gears should still be usable without a problem correct?
I bought the Richmond gears used with about 3k miles on them and the previous owner had just a bit of corrosion where it looks like the bearing is going to be pressed onto the pinion.
Thanks!
-Karl
Old 09-14-2008, 06:28 PM
02 BLK WS6's Avatar
Steel wool and wd40 ought to get the job done.
Old 09-14-2008, 07:44 PM
FirstYrLS1Z's Avatar
Wire wheel on a bench grinder,removes the surface rust but can't touch the tough/hard surface of the gearset.
